afWatch crashes afServer on MacOS
Posted: Fri Feb 25, 2022 9:33 am
i have correctly compiled CGRU on MacOS 11.6.2 (20G314) Big Sur.
i've set afServer and afRender on the same machine using its ip address in config.json.
afServer and afRender seems to work quite fine.
but whenever afWatch is launced and running, it seems to generate a very large memory footprint while interacting with afServer reaching in few swconds the whole ram usage, and then just clicking on any tab on afWatch (or even worst, just waiting) makes afServer crash.
this is the output coming from terminal:
same thing happens if i use the web interface on "myipaddress:51000" and don't even run afWatch
I've tried to setup afServer on a linux machine and both server and watch are working fine. I can control linux afServer with same afWatch from my macOS machine with no issues.
Am i doing something wrong?
Thanks in advance,
Ivan
AfQueue::pop: sem_wait() failed: Interrupted system call
zsh: segmentation fault /Users/mad/Documents/CGRU/cgru-3.2.2/afanasy/bin/afserver
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Thanks in advance,
Ivan
