No More Progress Bar in Afwatch
SteffenD
Post by SteffenD »
Hi there,
I noticed that Afwatch doesn't show a per-frame progress bar when rendering with Cycles any more (3.x+).
The syntax of the render log has changed to:
Fra:31 Mem:1232.12M (Peak 2206.01M) | Time:02:15.69 | Remaining:02:00.57 | Mem:1139.36M, Peak:1237.26M | SHOT010_Scene, ViewLayer | Sample 2128/4096
The "blender_cycles.py" parser contains:
for line in lines:
            # deal with new syntax
            status, perc = self.extractPercentage(line, '| Rendered ', 'Tiles')
            if status:
                self.percentframe = perc
                need_calc = True
            # deal with old syntax
            status, perc = self.extractPercentage(line, '| Path Tracing Tile ', ',')
            if status:
                need_calc = True
So, it expects either "Rendered" or "Path Tracing Tile" to read the percentage from the log but he new (let's call it Cycles X) syntax prints "Sample". My Python knowledge isn't good enough to add the new syntax.
Can anybody help me / us?
SteffenD
Re: No More Progress Bar in Afwatch
Post by SteffenD »
OK, I fixed it (hopefully, it's more like an educated guess at copy&paste ;) ).
# -*- coding: utf-8 -*-
from parsers import blender
class blender_cycles(blender.blender):
    """Blender Cycles
    def __init__(self):
        blender.blender.__init__(self)
    def extractPercentage(self, line, left_token, right_token):
        """Tries to extract the percentage of the current render progress in this line.
        Works with the old syntax:
            (...) RenderLayer | Rendered 136/510 Tiles, Denoised 96 tiles
        And the new syntax:
            (...) RenderLayer | Path Tracing Tile  136/510, Denoised 96 tiles
        Args:
            line (string) : blender cycles render output line to parse
            left_token (string) : separator string to extract the percentage on the left side
            right_token (string) : separator string to extract the percentage on the right side
        Returns:
            (bool) : True if a percentage got extracted, False if not
            (int)  : percentage value
        tokens = line.split(left_token)
        if len(tokens) > 1:
            tokens = tokens[1].split(right_token)
            numbers = tokens[0].split('/')
            if len(numbers) == 2:
                try:
                    part0 = int(numbers[0])
                    part1 = int(numbers[1])
                    if part1 > 0:
                        perc = int(100 * part0 / part1)
                        return True, perc
                except:
                    pass
        return False, 0
    def do(self, i_args):
        data = i_args['data']
        lines = data.split('\n')
        need_calc = False
        for line in lines:
            # deal with Cycles X syntax
            status, perc = self.extractPercentage(line, '| Sample ', '\n')
            if status:
                need_calc = True
            if status:
                need_calc = True
            if status:
                need_calc = True
        if need_calc:
            self.calculate()
        blender.blender.do(self, i_args)
If I find some time I'll try a pull request. In the mean time you can just replace the blender_cycles.py in /cgru/afanasy/python/parsers with these changes
EDIT: I tried my best and made a pull request. I hope I didn't break anything!
SteffenD
Post by SteffenD »
To get it running you have to update every client's blender_cycles.py and restart afrender
Thank You!
SteffenD
Post by SteffenD »
Just noticed that my "fix" is only partially working. As soon as Cycles uses "Tiles" (e.g. when you render resolution is > 2048 px in a default scene or you deliberately told Cycles to use tiles e.g. to save some memory), every single tile reports its render progress in the range from 0 to max samples, i.e. in a default scene with 4096 adaptive samples and 4 tiles, Cycles counts up from 0 to 4096 four times. My primitive "logic" does not handle this case, the progress bars move back and restarts several times which might look confusing.
My Python-fu is very very limited so maybe some real coder can fix this ;)
Does Blender(Cycles) prints some info about tiles count before the render?
If so, parser should parse tiles number first, then caclulate total percentage using tiles count.
SteffenD
Post by SteffenD »
Thanks for you quick reply :)
Yes, I just found this:
Fra:1 Mem:840.29M (Peak 1682.40M) | Time:00:06.59 | Remaining:18:15.69 | Mem:1147.60M, Peak:1153.71M | Scene, ViewLayer | Rendered 1/12 Tiles, Sample 80/4096
So there is info about the current tile / total number of tiles and of course the samples rendered.
So from this string
Rendered 1/12 Tiles
we can parse and store total tiles count and the current tile number.
SteffenD
Post by SteffenD »
Yes, but I'm an extreme coding noob :lol: and at least I can't do it.
Look at https://docs.python.org/3/library/re.html#match-objects
>>> import re
>>> re.search('Rendered (\d+)/(\d+) Tiles','Fra:1 Mem:840.29M (Peak 1682.40M) | Time:00:06.59 | Remaining:18:15.69 | Mem:1147.60M, Peak:1153.71M | Scene, ViewLayer | Rendered 1/12 Tiles, Sample 80/4096').groups()
('1', '12')
