Rendering doesn't work after upgrading to 3.3
vfxgeek
Post by vfxgeek »
I've just upraded all machines to CGRU 3.3 and everything seemed fine until I started a Nuke render, which renturned this:
Nuke 13.2v4, 64 bit, built Sep  5 2022.
Copyright (c) 2022 The Foundry Visionmongers Ltd.  All Rights Reserved.
Starting CGRU Nuke add-ons from:
/opt/cgru/plugins/nuke
Temp directory = "/tmp/.afrender.nuke.BRIDGE_102_015_0220_COMP_v012.nk.1004-191450-186.BRIDGE_102_015_0220_COMP_v012.nk-spotlights_matte.nk.4825"
Opening /media/PP/SC016/nuke_scripts/BRIDGE_102_015_0220_COMP_v012.nk.1004-191450-186.BRIDGE_102_015_0220_COMP_v012.nk-spotlights_matte.nk
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: profile 'Photoshop ICC profile': 'desc': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'wtpt': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'bkpt': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'rXYZ': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'gXYZ': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'bXYZ': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'dmnd': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'dmdd': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'vued': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'view': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'lumi': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'meas': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'tech': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'rTRC': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'gTRC': ICC profile tag start not a multiple of 4
libpng warning: iCCP: profile 'Photoshop ICC profile': 'bTRC': ICC profile tag start not a multiple of 4
Views = "main"
Number of views = 1
Rendering frame 201:
[19:14.59] ERROR: Read19: /media/PP/SC016/nuke_scripts/export/BRIDGE_102_015_0220_COMP_v012/BRIDGE_102_015_0220_COMP_v012_0400.exr: Read error: No such file or directory
Downgraded to 3.2 and eveything works again.
Lukas
Re: Rendering doesn't work after upgrading to 3.3
So, you want to say that when afrender-3.2 run Nuke, it see this file
And when afrender-3.3 run Nuke, it does not?
Path in both cases it the same and correct? This file exists exists in both cases?
If so, it means that process environment is differ.
vfxgeek
Post by vfxgeek »
Yes, this path is the same when using both CGRU versions. Works without any problems in 3.2
Strangly I also sent a Blender test render on CGRU 3.3, and that worked fine. The errors showed up only for Nuke renders.
What do you mean by process environment ?
Lukas
For example, process can run by other user and other user can't see some location.
Process can have different environment variables, and file path can depend on it.
You should ensure that your error is that:
The same Nuke, the same scene, can see and can not see the same file.
- it is a very strange situation, it is some system administration issue, what can cause it?
vfxgeek
Post by vfxgeek »
The afrender processes were run by the same user. Nuke is started from central location, so it's always the same version on all machines.
For now I had to go back to 3.2 as I'm in a middle of a project, so I can't do more tests for now.
My main reason for updating CGRU was to also upgrade Ubuntu to 22.04 - unfortunately CGRU 3.2 doesn't have a version for Ubuntu 22.04, or ?
Lukas
When you will have a time for test you should find out what caused an error.
Nuke says that it can't find file - if so, this is not cgru-afanasy issue.
