Job Fails to Start Due to Python Syntax Error
Anti-Distinctlyminty
Post by Anti-Distinctlyminty »
I am attempting to use afstarter to submit a generic command line job so we can quickly integrate an older piece of software into our farm (LightWave3D), but I'm getting some very strange errors.
I have configured the settings that result in the following
"python" "C:\ProgramData\Rez\cache\cgru\3.3.0-b75c1cb\0368\a\cgru\afanasy\python\afjob.py" "T:\__TO_BE_DELETED\CGRU_Lightwave\scenes\lightwave_test.lws" 1 10 -by 1 -fpt 1 -seq 1 -extrargs "-3 T:\__TO_BE_DELETED\CGRU_Lightwave\scenes\lightwave_test.lws" -os any -pwd "T:\__TO_BE_DELETED\CGRU_Lightwave\scenes" -name "lightwave_test.lws" -exec "T:\__LightwaveFarm\Lightwave2020.0.3\bin\lwsn.exe"
Which submits successfully and attempts to render. However, during a render attempt I get the following output:
LightWave AMD64 ScreamerNet Module (Build 3227)
CPU number: 862
  File "C:\ProgramData\Rez\cache\cgru\3.3.0-b75c1cb\0368\a\cgru\python\lib\site.py", line 178
    file=sys.stderr)
SyntaxError: invalid syntax
Now, the correct executable seems to be starting (lwsn.exe) indicated by the text "LightWave AMD64 ScreamerNet Module (Build 3227)", but then after that we get the Python syntax error. My guess is that the Python embedded in lwsn.exe is too old but is picking up some environment variable or sys.path and trying to scan teh cgru python code which is too new.
Any ideas on how to circumvent this?
Re: Job Fails to Start Due to Python Syntax Error
It seems to be caused by the PYTHONHOME environment variable that is set by setup.cmd being inherited by the executed command.
Is there any mechanism to prevent this environment variable (or all environment variables) being inherited?
Yes, your software tries to use CGRU Python, but should use own older version.
You should empty PYTHONHOME variable:
set PYTHONHOME=
CGRU software setup do this for all soft:
https://github.com/CGRU/cgru/blob/maste ... p__all.cmd
You should make a cmd script wrapper to make your soft not to launch directly, but after some environment turning.
I'll look into this further, thank you.
