Blender Parser Needs Update
Posted: Fri Oct 13, 2017 12:30 pm
by SteffenD
Hi there!
First of all let me thank you for giving us this awesome render manager software. We've been absolutely hammering our farm during the last months and it has been rock solid and super easy to setup!
Today I noticed that with the latest Blender (own builds from current master and current builds from Buildbot) the progress during rendering isn't updated any more.
This comes from a change that Brecht recently made. Instead of "... Path Tracing Tile 26/40 ..." Blender now outputs "... Rendered 26/40 Tiles..." and the parser doesn't recognize this change.
This will affect all future versions of Blender.
I guess the change should be made in ..\cgru\afanasy\python\parsers\blender_cycles.py
Thanks!
Re: Blender Parser Needs Update
Posted: Sat Oct 14, 2017 9:02 am
Look for blender*.py files here:
https://github.com/CGRU/cgru/tree/maste ... on/parsers
May be some changes needed to adopt new version.
You can make changes and create a pull request on github to contribute to the project.
Check that render engine is recognized correctly.
Posted: Mon Oct 16, 2017 12:05 pm
by SteffenD
Hi timurhai,
thanks for your reply. I'm not a coder at all but I managed to hack the blender_cycles.py to work with the latest master. It's kind of dirty I guess and no longer working with the official releases.
I just changed line 5 to:
and line 22 to:
parts = line[ptpos + len(keypart):].split(' Tiles,')[0].split('/')
Someone with a bit of Python knowledge should look over this and maybe add some magic to allow both kinds of Cycles to report the progress by accepting both, the old and the new "keypart".
Posted: Wed Oct 25, 2017 12:18 pm
by SteffenD
OK, so here is a version that's working with both, the old and the new syntax of Cycles's output (Thanks to my Python wizard who had a quick look):
# -*- coding: utf-8 -*-
from parsers import blender
class blender_cycles(blender.blender):
"""Blender Cycles
def __init__(self):
blender.blender.__init__(self)
def extractPercentage(self, line, left_token, right_token):
"""Tries to extract the percentage of the current render progress in this line.
Works with the old syntax:
(...) RenderLayer | Rendered 136/510 Tiles, Denoised 96 tiles
And the new syntax:
(...) RenderLayer | Path Tracing Tile 136/510, Denoised 96 tiles
Args:
line (string) : blender cycles render output line to parse
left_token (string) : separator string to extract the percentage on the left side
right_token (string) : separator string to extract the percentage on the right side
Returns:
(bool) : True if a percentage got extracted, False if not
(int) : percentage value
tokens = line.split(left_token)
if len(tokens) > 1:
tokens = tokens[1].split(right_token)
numbers = tokens[0].split('/')
if len(numbers) == 2:
try:
part0 = int(numbers[0])
part1 = int(numbers[1])
if part1 > 0:
perc = int(100 * part0 / part1)
return True, perc
except:
pass
return False, 0
def do(self, data, mode):
lines = data.split('\n')
need_calc = False
for line in lines:
# deal with new syntax
status, perc = self.extractPercentage(line, '| Rendered ', 'Tiles')
if status:
self.percentframe = perc
need_calc = True
# deal with old syntax
status, perc = self.extractPercentage(line, '| Path Tracing Tile ', ',')
if status:
need_calc = True
if need_calc:
self.calculate()
blender.blender.do(self, data, mode)
Posted: Mon Oct 30, 2017 1:07 pm
Great!
You can make a pull request here:
to share your work with others!
Posted: Tue Jan 07, 2020 10:41 am
by SteffenD
Sorry for taking so long but yesterday I added a pull request to github.
