Finished PID=1628.:Exit Code=3 Status=3 Error: Parser bad result .
Robinson
Post by Robinson »
COMPUTERNAME=MS-201511222154
2017/2/27 22:28:25; Parsing scene: "D:\3dMaxProjTest\rectangle.max"
2017/2/27 22:28:25; Error opening scene file: "D:\3dMaxProjTest\rectangle.max"
2017/2/27 22:28:25; 1 frames initialized
2017/2/27 22:28:25;
Max install location: C:\Program Files\Autodesk\3ds Max 2014\
2017/2/27 22:28:25; Max file being rendered: D:\3dMaxProjTest\rectangle.max
2017/2/27 22:28:25; Renderer:
2017/2/27 22:28:38; [V-Ray] ============================================================
2017/2/27 22:28:38; [V-Ray] Console created, V-Ray A for x64 from Feb 16 2014, 23:06:27
2017/2/27 22:28:39; [V-Ray] Compiled with Intel C++ compiler, version 12.1
2017/2/27 22:28:39; [V-Ray] Host is 3dsmax, version 16
2017/2/27 22:28:39; [V-Ray] V-Ray DLL version is 3.00.02
2017/2/27 22:28:45; Max is ready
2017/2/27 22:28:45; Frame 1 assigned
2017/2/27 22:28:45; Error creating Bitmap
2017/2/27 22:28:45; Render Error (Initializing Renderer)
2017/2/27 22:28:45; Error rendering frame 1: Render Error (Initializing Renderer)
2017/2/27 22:28:45; Send End of Job command to Max
2017/2/27 22:28:46; Job Completed with Error(s) - see above
2017/2/27 22:28:46; Total elapsed time 00:00:01
2017/2/27 22:28:55; Error occured while rendering job.
Can anybody help me ?
CGRU 2.2.1
Re: Finished PID=1628.:Exit Code=3 Status=3 Error: Parser bad result .
It seems that 3dmax process has some error(s).
You can try to launch task command simple in a console for tests (to get command double-click its task).
I head that 3dsmax can't work (or has limited functions) in command line mode, without backburner installed.
( it is a 3dsmax native render manager )
It will be more helpful if you always specify CGRU version.
You can write it in your signature.
Robinson
Post by Robinson »
Thanks timurhai.
My CGRU is 2.2.1
I will try your suggestion. :)
CGRU 2.2.1
* topic moved in this section
