Posted: Wed Feb 05, 2020 3:58 pm
by nutellaj
One of the computers in the local network refuses to render frames sent through Submit Job from manager computer. Other computers render without any problems.
It shows Exit Code -1073741819
This is the command it runs: mayarender -r file -s 1 -e 1 -b 1 -cam "camera1" -rd "O:\carriage" "P:\0_assets\0_props\carriage\2_shading\carriage_shading.0014.ma"
Afanasy info: https://pastebin.com/fnc5wfUi
I checked env variables, i checked if afanasy sees the software, i checked that the render from the computer itself works. Everything seems to be ok, but it still doesn't want to render.
Could you please help troubleshoot this?
Thanks.
Software: Maya 2019.1
Windows 10 pro x64 build 1903
cgru ver 2.3.1
Posted: Thu Feb 06, 2020 8:42 am
Hello.
You want to say, that the same command
returns some different exit code on some machine?
Have you tried this command w/o Afanasy, just paste it in a console, and check exit code?
Posted: Thu Feb 06, 2020 11:56 am
by nutellaj
I went to afanasy terminal and ran the mayarender command and it just returns me the computer name.
In another computer render kicks in and completes successfully.
I see exit codes in terminal from render.cmd
Posted: Thu Feb 06, 2020 12:07 pm
So now you see your problem.
You should dig what is going on, what is the difference between computers.
May be mayarender script can't find Maya installation directory?
Posted: Thu Feb 06, 2020 1:53 pm
by nutellaj
It seems like something is wrong with maya.
mayarender command is basicallu Render.exe called with arguments.
And Render.exe doesnt work either. Maybe i'll just wipe the OS :)
Posted: Thu Feb 06, 2020 3:09 pm
Ensure that it found Render.exe location.
