Afserver crashes
Re: Afserver crashes
or maybe you can give me a good hint on how to properly attach valgrind so we have more debug info.
As it crashes on a new thread start, i can say the exact SIGSEGV point in the code:
https://github.com/CGRU/cgru/blob/maste ... d.cpp#L255
But unfortunately for now i can't say why we have some probability to hung there.
And why this probability is differ on different platforms.
Pthread library uses system "clone" call.
For now i do not know what we need to know more and what more can valgrind say, but may be it can help more.
I just wrote (and committed) threads raising test:
https://github.com/CGRU/cgru/blob/maste ... st.cpp#L41
It is an afcmd command that do almost the same as afserver on each new connection.
Strange results:
On my laptop (ubuntu16 gcc 5.4) i can raise 1 000 000 threads. Tried many times - no crashes.
But afserver crashes on this platform on when i spawn 200 afrenders.
At work (ubuntu14 gcc4.8) this test can crash staring from 1000 threads and definitely crash on 100 000 threads.
But i can`t crash afserver on this platform, including crash-tests with 200 afrenders.
I should read about pthread library more. Likely that afanasy uses it some incorrectly.
( note that DlThread class was just taken from 3delight, that is not a server, but render engine )
You are welcome to test this command on your platforms.
Strange results:
I am not able to get it to crash ....
@selsner,
Are you on a 32 or 64 bit kernel running the afserver?
Timur,
Why is the stack size for each thread so large? I have been testing an afserver with the thread stack size set to 32768 which reduces the virtual memory usage. I couldn't find where
the stack size was being set so I add this pthread_attr_setstacksize(&attr, 32768); to dlThread.cpp
Have a look at the first answer of this post:
http://stackoverflow.com/questions/5585 ... -of-memory
Scott
Timur,
Scott
So on my afserver machine each pthread stack uses 10485760 of virtual memory on a stock 2.2.1 afserver.
Here's the patch code if someone would like to try it:
Scott
--- dlThread.cpp 2017-03-15 12:09:05.300428237 -0700
+++ dlThread.cpp.mod 2017-03-15 12:08:45.772250461 -0700
@@ -23,6 +23,7 @@
/* The following chunk are for GetNbProcessors. */
#ifdef LINUX
#include <sys/sysinfo.h>
+#include <stdio.h>
#endif
#ifdef IRIX
@@ -246,6 +247,12 @@
#else
pthread_attr_t attr;
pthread_attr_init( &attr );
+ pthread_attr_setstacksize(&attr, 32768);
+// size_t size;
+// int ret = pthread_attr_getstacksize(&attr, &size);
+// printf ( "Get: ret=%d,size=%u\n" , ret , size ) ;
if( detached )
pthread_attr_setdetachstate( &attr, PTHREAD_CREATE_DETACHED );
Scott
May latest post and commit has a mistake.
DlThread does not check whether the thread was started.
And does return void from Start() function.
We can't raise 1 000 000 threads at the same time.
That test just stops to raise threads at all w/o any error message.
Normally on Linux you can't spawn more than 32k threads, and this is more than enough for us.
Now changed DlThread to return an integer that pthread_create returns.
And added a check in afserver and afcmd test.
https://github.com/CGRU/cgru/commit/583 ... c985e005b3
Also 1ms sleep was added in afcmd raise threads loop.
Afcmd test threads sleeps (life) 1second, so there is 1s/1ms = 1000 thread at the same time, and this is much less than the limit (32k).
Now 1 000 000 test will take some time, but it was passed (on ubuntu16).
I also performed a 200 afrenders test (on ubuntu16), but i did not get any new error message from pthread_create.
Just segmentation fault:
Backtrace:
/lib/x86_64-linux-gnu/libpthread.so.0(pthread_create+0x4ff)[0x7f1a1777ee8f]
afserver(_ZN8DlThread5StartEPFvPvES0_+0xc5)[0x4c96d5]
afserver(_Z16threadAcceptPortPvi+0x509)[0x45f049]
So now i am at the same point as before.
Continue digging this issue...
Backtrace:
@seven11
Great idea!
I added:
And it works for about a half an hour!
It never works so long on my testing system.
Reading more about stack size...
Great idea!
I added:
Great! I'm going to pull down the new afserver code and test it.
Scott
Scott
Timur,
So I'm now running a Git pull of 2.2.2 with the pthread stack size set to 32K on a Centos 6.5 x86_64, 4 Proc, 8Gig Ram.
I can spawn a 1000 threads with the " afcmd tthr 1000" command. No issues so far.
I'll keep you posted...
Scott
Scott
