afanasy jobs finish query
rsegev
Post by rsegev »
Hello Timur,
Is it possible to query the afanasy for job completion?
In the afanasy watch I can see job completion in the GUI so I need the same functionallity via API.
Thanks.
Re: afanasy jobs finish query
Here is some json examples:
https://github.com/CGRU/cgru/tree/master/examples/json
You can also look at web gui network log.
If you run afwatch from a terminal on Linux you will see how it communicates too.
But "job completion" more sounds like an event, not a data.
You can't query en event. You can query (get) a job object.
