Hello sir
Can you please describe the sub group options of "set parameter" and "Task block" options.
I m using some of but the rest i wants to use for to make more user friendly AFANASY for render monitoring.
Using sub group option "set perameter" and "Task block"
Re: Using sub group option "set perameter" and "Task block"
This is designed to change some parameter value.
Job parameters are described here:
http://cgru.info/afanasy/job#job_parameters
