This is something which is confusing new users of Afanasy (atleast on my end).
"Render" is usually refering to an output of a "Render job/task".
Deadline : "Slave"
Qube : "Worker"
Tractor : "Blade"
RoyalRender : "Client"
Render Pal : "Client"
Smedge : "Engine"
Flamenco : "Worker"
Backburner : "Server"
My suggestion would be either "Render Node" or just "Node".
Rename "Render" to something else
Re: Rename "Render" to something else
May be it is a good idea.
But not into 'Node'
As in the code, there is 'af::Node', that is a base class for any node in a container.
Job, render, monitor classes are based from 'af::Node'.
Or we should rename lots it in the code.
But not into 'Node'
Also 'Client' is used in a code too, it is any client, and GUI(monitor) and render.
'Server' and 'slave' words are used too
Server is afserver, slave is used in multi-hosts tasks along with 'master'.
Yes, Server is the worst possible name for a Render Node
Blade perhaps?
It seems that afermer is already using that term.
And Blade is also used as a term for physical machines.
Blade perhaps?
May be.
But not for now, so much to rename...
( at least it should be 2.3.0 )
Lets keep this issue, may be some other names we will think up.
Yes, or perhaps even wait for 3.0?
I'd normally vote for "slave", "worker", or "node", but given the already-used nature of most of the good names, I'd even recommend just "renderers" - the problem is that the "render" button looks like a verb, an action you can do, not a tab filled with the nodes doing the rendering.
