How to separate render job to a specified render machines
ramdhandwi
Post by ramdhandwi »
I am not a programmer, but I use Afanasy frequently.
Now, I am facing new problem. I have 5 fast computers to render and 10 slow computers. I want to set fileA (mostly environments) for faster computers, and fileB (characters and props only) for slow computers. Is it doable to do such things?
I tried to use host mask, but I don't find anywhere to set the computer host. It would be helpful to know how to set this up.
Thanks.
Re: How to separate render job to a specified render machines
You can set it during job construction, via JSON protocol, within GUI.
http://cgru.info/afanasy/job#job_hosts_mask
Remember that hosts mask is a regular expression.
ramdhandwi
Hi Timur, thank you very much.
It turns out, I made a mistake when naming the computers, I have the same name for all the fast computers. So when I use "Hosts Mask", afanasy didn't recognize it. So... I go to my server and change the name of my renderer by going to the "c:\temp\afanasy\renders\0". all the renderer data are located there. I change it manually one by one. and then after that, I can use the "hosts mask" again.
now, I can submit a job and also assign which renderer is going to do it by grouping them by name.
Afanasy is awesome! thanks again.
