I can submit my render to farm by creating bundle list but cgru throws this error
This is a log
The Houdini 17.0.459 environment has been initialized.
/opt/cgru/plugins/houdini
HOUDINI_CGRU_PATH = '/opt/cgru/plugins/houdini'
File "/opt/cgru/plugins/houdini/hrender_af.py", line 70, in
hou.hipFile.load(hip)
File "/opt/hfs17.0.459/houdini/python2.7libs/hou.py", line 35203, in load
return _hou.hipFile_load(*args, **kwargs)
hou.OperationFailed: The attempted operation failed.
Error loading: houdini/gishant.singh/untitled.hip
Warning:
/obj/arnold_spot_light1:
Unknown channel(s) "ar_color_family" converted to spare parameter(s).
Skipping unrecognized parameter "ar_color_space".
Skipping unrecognized parameter "ar_autotx".
Skipping unrecognized parameter "ar_aov_indirect".
Error: Unknown operator on load "arnold_vopnet.net".
Warning:
/obj/ropnet1/arnold1:
Skipping unrecognized parameter "folder_camera".
Skipping unrecognized parameter "folder_subdivision".
Skipping unrecognized parameter "ar_subdiv_frustum_culling".
Skipping unrecognized parameter "ar_subdiv_frustum_padding".
Skipping unrecognized parameter "folder_objects".
Skipping unrecognized parameter "folder_shaders".
Skipping unrecognized parameter "folder_lights".
Skipping unrecognized parameter "ar_ass_export_shader_assignments".
Skipping unrecognized parameter "ar_ass_export_operators".
Error: Problem while synchronizing child node:
Error: Bad node type found: arnold_vopnet in /obj/arnold_spot_light1/shopnet.
Bad node type found: arnold_light in /obj/arnold_spot_light1/shopnet/arnold_vopnet1.
Unknown operator on load "arnold_spot_light1/shopnet/arnold_vopnet1/OUT_light".
Please Help!!
Arnold in Houdini submit to farm render issue
Re: Arnold in Houdini submit to farm render issue
This error was thrown by Houdini on hip file load.
It found unrecognized parameters and node types.
It seems that you and afrender running Houdini under different environments.
Try launch Houdini from CGRU Keeper and open that file. Will that errors preset?
Hey,
This the environment which I have set in houdini.env
This is the error
HOSTNAME=localhost.localdomain
Houdni location = '/opt/hfs17.5.460'
The Houdini 17.5.460 environment has been initialized.
LaunchProgram: chdir(): : Permission denied
File "/opt/hfs17.5.460/houdini/python2.7libs/hou.py", line 35900, in load
Unable to open file: /home/khiladisngh/houdiniprojects/cgru/cgru-afanasy1-_current_-r1280.0805-190256-870.hip
CGRU_LOCATION = "/opt/cgru"
HOUDINI_CGRU_PATH = "$CGRU_LOCATION/plugins/houdini"
PYTHONHOME = "$CGRU_LOCATION/python"
PYTHONPATH = "$PYTHONPATH;$HOUDINI_CGRU_PATH;$CGRU_LOCATION/afanasy/python;$CGRU_LOCATION/lib/python;&"
CGRU_PYTHON = "$CGRU_LOCATION/lib/python"
AF_ROOT = "$CGRU_LOCATION/afanasy"
AF_PYTHON = "$CGRU_LOCATION/afanasy/python"
HOUDINI_OTLSCAN_PATH = "$HOUDINI_CGRU_PATH;$HOUDINI_OTLSCAN_PATH;&"
This is the error
There is a concrete error message:
Houdini (hython) can't open this file.
Whenever I run from Keeper it doesn't throw this error but after setting the environment it shows this.
So, your Keeper and afrender environments are differ.
