after certain time the afrender.service is stopped
kamlesh0999
Post by kamlesh0999 »
hello
my afrender.services is stopped again n again and my nodes gone to offline do you have any idea what is reason behind that
in my log there is ZOMBIETIME showing in the error
kamlesh0999
Re: after certain time the afrender.service is stopped
This is the error i have got in my log
Tue 8 Sep 13:40.41 : Initialized from store.
Mon 8 Sep 3:40.47 : Registered offline.
Thu 10 Sep 00:27.21 : Online '2.3.1'.
Thu 10 Sep 00:27.21 : ZOMBIETIME: 3600 seconds.
Thu 10 Sep Jun 00:27.21 : Ejecting task: [houdinitoarnold] vishal.mewada: test_cam4_masterLayer.vrscene[vray][frame 54]
Thu 10 Sep 00:27.21:
Resources: la[0,0,0]; C3492x8 u100% n0% s0% i0% o0% r0% f0%; M16281 F3568 C0 B0 S32560/12840 H59/15 N1/0 D0"3:0%
Thu 10 Sep 00:28.07: : Offline.
Some network problem.
If you are using windows, you will always have problems with any soft.
kamlesh0999
no no we are using linux and if you have any idea please tell us how to fix this problem
Your afrender could not connect to afserver for 3600 seconds.
This is the only information you give me.
There can be lots of reasons.
This can be a network problem or may be afrender process was crushed?
You should see afrender process output.
kamlesh0999
we have lots of blades and all are suddenly gone to offline when i have checked there is afrender.service stopped in all node
