Can't Connect Database on CentOS 8
Khiladi
Post by Khiladi »
I am done with all the steps for installation also postgres is working and database has been created but Its throwing this error while running afcmd db_check
Thu 15 Oct 01:31.20: WARNING Config file does not exist: /root/.cgru/config.json
Project was build without SQL library.
AFERROR: afanasy.cmd.Check: Database connect failed: (null)
Database connection is NOT WORKING !
Regard
Re: Can't Connect Database on CentOS 8
Ops...
It seems that i missed something building the project on CentOS 8 ((
You can re-build project manually.
Or wait, i will update the latest 3.1.0 release.
Khiladi
Post by Khiladi »
Hey Timur Thanks man,
But right now I am getting another error while db_check command I am getting this error.
[khiladi@localhost cgru]$ afcmd db_check
afcmd: /usr/pgsql-12/lib/libpq.so.5: no version information available (required by afcmd)
Fri 16 Oct 05:52.43: WARNING Config file does not exist: /opt/cgru/config.json
WARNING: SERVER ADDRESS IS NOT CONFIGURED, USING 127.0.0.1
Database connection is working.
[khliadi@localhost cgru]$
Regards
I do not see any error...
Khiladi
Post by Khiladi »
So this is just a warning
Regards
I never saw such message.
You can try to ask on PostgreSQL forums.
Khiladi
Post by Khiladi »
Understood,
You may check Windows Build too as it is giving that same error
Regards
I never have to set up sql server on windows.
Generally, windows is not a server os.
You are going to use render manager server with a postgresql server on windows?
I never met such requests.
