I found that same jobs are rendering extremerly different speed via afanasy and working soft. For example if I render via Nyk the ETA takes 30 min, but if I start job using afanasy it takes 3 hours. Why its happen? Could you please give some advise fo fix it and reduce the render time.
I have only one working station and server are the same machine
Thank you in advance!
