all render tasks getting reseted
cg-cnu
Post by cg-cnu »
Hi guys,
Having a weird issue over the last few weeks. We are keeping overnight renders and they are going good. :) But, once in a while when we come in the morning and start checking from the monitors(web/afwatch) the network will freeze for a minute. And, once its back, all the renders happening from hours will be restarted on all the nodes in one go. :shock:
Here is the afanasy logs from the server...
Fri 10 Feb 08:27.54: Monitor zombie: coord@pc-14[17] e'firefox' 192.168.1.79
172806 Fri 10 Feb 08:27.54: Monitor zombie: coord@pc-21[24] e'firefox' 192.168.1.79
172807 Fri 10 Feb 08:27.54: Monitor zombie: <user>@<FQDN> e'2.1.0' 192.168.1.76
172808 Fri 10 Feb 08:27.54: Monitor zombie: coord@pc[2] e'firefox' 192.168.1.57
172809 Fri 10 Feb 08:28.14: Render: <ip> - ZOMBIETIME
172810 Fri 10 Feb 08:28.14: Render Offline:  off                    <FQDN>@render[31] 192.168.1.96
172811 Fri 10 Feb 08:28.14: Render: <ip> - ZOMBIETIME
172812 Fri 10 Feb 08:28.14: Render Offline:  off                    <FQDN>@render[30] 192.168.1.98
172813 Fri 10 Feb 08:28.14: Render: <ip> - ZOMBIETIME
172814 Fri 10 Feb 08:28.14: Render Offline:  off                    <FQDN>@render[8] 192.168.1.93
Re: all render tasks getting reseted
Sorry, to few info, can't say anything. Try to 'catch' the bug.
cg-cnu
Post by cg-cnu »
Anywhere specific I should look into? Any info which will help you in understanding the issue.
Am also trying to understand the logs...
Few questions for you.
Why are the monitors showing as 'zombie monitor'
What does "ZOMBIETIME" mean.
Thanks!
Terminology 'zombie' took from Linux processes.
( Node class can't delete itself, but can consider that it is not needed, it set zombie to true, then container deletes zombie nodes )
Renders and monitors became zombies after some time they have not connected to server.
40 seconds for monitors by default:
https://github.com/CGRU/cgru/blob/maste ... .json#L174
So your clients that should ask server for some new events every second, can't reach server for a long time.
May be server connections queue is full?
How many client your afserver serves?
How many open sockets it has?
What is open sockets state?
There lots of commands&utilities for sockets monitoring, here are some:
netstat -nat | grep 51000 | wc -l
netstat -nat | egrep ':51000.*:.*TIME_WAIT' | wc -l
ss -tan state time-wait | wc -l
ss -tan 'sport = :51000' | awk '{print $(NF)" "$(NF-1)}' | sed 's/:[^ ]*//g' | sort | uniq -c
( it is separated commands as examples, do not type all lines together )
PS
Even jobs and users became zombies just before deletion, but it is not visible.
cg-cnu
Post by cg-cnu »
Here are the results from the commands right now in the server.
297
297
309
     32 192.168.1.53 192.168.1.63
     54 192.168.1.57 192.168.1.63
     98 192.168.1.79 192.168.1.63
     33 192.168.1.82 192.168.1.63
     53 192.168.1.90 192.168.1.63
      1 Address Peer
The issue is happening only in the morning after full night of renders.
I will check the stats in the morning and update you.
I will monitor the sockets status and let you know.
We have around 50.
Thanks for the help! I will get back with more information.
Not much clients.
Not much open sockets.
Should work.
Also you can raise up open descriptors limit in the system - default for most distributives is 1024 - it is not much for servers, set at least 10240.
