Is there a way of controlling where the "Post Command" will execute?
Say for example always on render node 1.
Scott
Post Command execution
Re: Post Command execution
System job and its blocks has the same parameters as any other job, and you can manipulate them.
You can set hosts mask, configure block service and specify hosts that can run it in a farm setup.
So when we use the nuke AF submission script and the job has completed and I want to delete the nuke job I find it picks any machine randomly from the mask
to delete(command_post) the .nk file. How would I set the command_post to run on the same machine every time?
Not a bug, a feature requestseven11 wrote: ↑Thu Mar 02, 2017 9:26 pm Timur,
Aah I see it's a bug on github #308.
https://github.com/CGRU/cgru/issues/308
Scott
